Unconfigures the minimum time between unsolicited router discovery advertisements on the VLAN.
| vlan_name | Specifies an IPv6 configured VLAN. |
N/A.
This command sets the min-interval parameter to the default value of (max-interval × .33 seconds).
The following example unconfigures the min-interval for the VLAN "top_floor":
unconfigure vlan top_floor router-discovery min-interval
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
